Transparent Cherry mx key caps
Go to solution Solved by PopReference,
No I meant just where the light shines though the letter of number it displays.
Okay.
I haven't seen many options for that unfortunately. For textured and backlit I can only find the Corsair FPS set.(http://www.corsair.com/en-ca/fps-backlit-key-caps-keycap-puller-and-palm-rest)
As for full sets with backlit keys the only one I can find is the Vortex sets,(Black/White) their not much more textured then stock boards but they are a different materials, they have a few downside though but it's your choice if you want to try it.
I did find this though: http://www.geekkeys.com/dota-2-backlight-keycap/
I'm looking for transparent cherry mx key caps for my K70. But not just any transparent key caps would do, no I want ones with texture for my Dota needs. It would be great to feel if my left hand is in the right position. Currently I have the textured S key that gets shipped with the keyboard replaced with the R key cap, now my right index finger feels the key. Something less ghetto would be nice though.
Thanks in advance.
https://linustechtips.com/topic/353795-transparent-cherry-mx-key-caps/
Maybe someone can 3d print you some
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
Okay.
