I never used it before,but whenever i try to make server as told in several guides i get error "impossible to access the device" ... I downloaded ventrilo,i downloaded the server file..Someone can give me some advice?
I've never gotten that error, and I've run and hosted vent servers for years. I will say that the port for ventrilo MUST be forwarded to the outer internet.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/353609-ventrilo-problems/#findComment-4805724
After i downloadand install ventrilo client 64 bit it starts and everything...But after i download the file called "windows i386-32 bit and after installing it i cant open it..i get "can not access the specified device, path or file specified. it is likely that you do not have permissions" i tried everything like running it as admin,as normal user but nothing works...
https://linustechtips.com/topic/353609-ventrilo-problems/#findComment-4812421
