I am looking to build my first computer.
These are the parts that I am thinking about using to construct my computer:
CPU: i5-4690K
MoBo: Gigabyte GA-Z97X-Gaming 7
RAM: Corsair Vengence 2x4GB
CPU Cooler: Corsair H100i
SSD: Crucial MX100 128GB
HD: WD Caviar Blue 1TB
GPU: EVGA GeForce GTX 960 2GB Superclocked
Case: NZXT S340 White
PSU: Corsair CX750W 80+ Bronze
Can anybody tell me if this is a pretty solid build?  My biggest worry is that I cannot really tell a good MoBo for a crappy MoBo.
Robert
https://linustechtips.com/topic/352599-building-my-first-computer/
Downgrade the motherboard to an MSI or Gigabyte Gaming 5, get a better power supply (maybe a Capstone or a G2), ditch the H100i for a Cryorig H5 and get a GTX 970. Better performance all around.
As it stands, it's solid but better can probably be done for the money.
go with a 4GB 960, they are a better deal.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
CPU: i5-4690K
Robert
Use the stock cooler and get a r9 290 or gtx 970
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
ssd should be a bigger..
skip the 960 and get a amd 280...faster for around the same..maybe a 280x
change the psu to a seasonic 620w or xfx
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
Thanks a lot for the quick input...
I was trying to keep my budget in the $1000 range.
And for the size of the SSD... I was only planning on using it for a boot drive for the OS.
I will definitely look into all the suggestions that are being made...
Thanks
And for the size of the SSD... I was only planning on using it for a boot drive for the OS....you'd be surprised how fast a 120gb ssd fills up with the OS and programs
Thanks
Well, considering that we can get a 970 under 800$ (with a bit of effort), I think it's safe to say that with 1000$ we can do it as well. Here. Enjoy it.
EDIT: I've made some changes. Just 1$ overbudget, but VERY powerfull. The GPU link can be found here. Enjoy your awesome build:
CPU Cooler: Enermax ETS-T40-W 105.9 CFM CPU Cooler  ($44.98 @ OutletPC)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($57.98 @ OutletPC)
Case: NZXT S340 (White) ATX Mid Tower Case  ($64.99 @ Micro Center)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.79 @ OutletPC)
Total: $1001.56
Generated by PCPartPicker 2015-04-21 17:35 EDT-0400
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
all good advice for OP, just remember the most important piece of advice ... enjoy every minute of the build
i5 4670k @4.2ghz / MSI Z87 G45 / EVGA GTX 960 SSC / Samsung  840 EVo SSD / WD Green 1tb HDD / Corsair H75 / Corsair Obsidian 750D / Corsair CS750M
First time post for a first time build!
All of my parts (sans case, which should be here tomorrow!!) arrived today for my first build too!!
CPU: AMD FX 8350
GPU: ASUS Radeon R9290x
MoBo: ASUS M5A99FX
PSU: EVGA SuperNOVA 850w 80+ gold
SSD: 2x Intel 730 series 240 GBs each
RAM: G Skill Ripjaw X 16 GBs
HDD: WD 1TB Black series
Cooler: Corsair hydro H105
Case: NZXT H440 (Blue and black)
I'm working towards a blue/black themed build. The MoBo, RAM and Case are going to look so good together. I have BassPulse Pro speakers that are blue LEDs. It's all going to look so good when it's done! I'm super excited for all of this!
CPU: AMD FX 8350
MoBo: ASUS M5A99FX
The next time you make a build, remember to consult us befor buying parts. Quite honestly, those specs are really bad, you wasted A LOT of money.
