Parameters:
Must support video card 12" in length.
Must support CPU Cooler of 6.5" in height.
Must support ATX MotherBoard.
Must be ATX full tower or mid tower.
What are your guys' favorites? Make your cases! (Pun intended)
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/352418-best-case/
Budget?
Ideally less than $70 for a mid tower, full towers can be more.
Solitaire.
https://linustechtips.com/topic/352418-best-case/#findComment-4791062
i am a phanteks guy soooo yeaaaa
enthoo 4 life
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/352418-best-case/#findComment-4791064
best full tower is the enthoo pro, its 100$ and you get
"11/10 cable management" -IGN
"swaggy PWM fan hub" -PC Gamer Magazine
and a cool window, the only downside is that the window the scratch easily
as far as mid towers go for 70$ you can't go wrong with the S340
https://linustechtips.com/topic/352418-best-case/#findComment-4791074
I was looking at the Corsair 200R or the 750D
Solitaire.
https://linustechtips.com/topic/352418-best-case/#findComment-4791075
R5 is cheaper than 750D O.o
Is R5 full tower?
Solitaire.
https://linustechtips.com/topic/352418-best-case/#findComment-4791098
750d is too damn big, unless you want to 3way sli or higher, if not, 450d is gonna do gr8
https://linustechtips.com/topic/352418-best-case/#findComment-4791100
Is R5 full tower?
nope tis a mid tower
https://linustechtips.com/topic/352418-best-case/#findComment-4791103
I want a full tower for potential expansion and cable management, and the Enthoo Pro looks good and its relatively cheap.
Anybody want to buy a RoseWill Galaxy-01 with no fans? :P
Solitaire.
https://linustechtips.com/topic/352418-best-case/#findComment-4791122
R5 has amazing cable managment and can easily fit 2 graphics cards which is maximum you should ever use, but enthoo pro is nice case too.
https://linustechtips.com/topic/352418-best-case/#findComment-4791129
Mid but why can you spend so much more money on full tower?
I dont think a mid tower is worth that much money, especially when the Corsair 200R is $50, i would be willing to spend more on a full tower because it is literally more case.
Solitaire.
https://linustechtips.com/topic/352418-best-case/#findComment-4791136
Mid towers are best unless you plan to do crazy SLI watercooling stuff. Full cases are too big, waste space and make all your other components look tiny :)
https://linustechtips.com/topic/352418-best-case/#findComment-4791152
