I am planning a case, with side panels on a hinge.
I have 4 ideas.
One: the side panels hinge open, each having half of the front panel.
This would lead to a Seam in the middle I should have to cover.
2: the side panels hinge, the left having entire front panel connected, leading to no Seam
C: same as above, but right panel has front
IV: each hinges open, the front is fixed, no seam.
Please comment below, and ask if you don't understand
https://linustechtips.com/topic/352316-case-design-question/
I have 4 ideas.
I like this:post-130253-0-29197300-1429618712_thumb.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/352316-case-design-question/#findComment-4789651
Do It like a car door
What do you mean?
https://linustechtips.com/topic/352316-case-design-question/#findComment-4789860
The case will be to compact to do that
https://linustechtips.com/topic/352316-case-design-question/#findComment-4789864
You building it from scratch of do you have a base?
https://linustechtips.com/topic/352316-case-design-question/#findComment-4789917
I may not be doing anything.
My head is just full of ideas.
But I'm thinking a wood/glass/aluminum/leather case
https://linustechtips.com/topic/352316-case-design-question/#findComment-4789930
