Be quiet dark rock pro 2 blocking pci slots in fractal design define r4
Solved by Tardbarn,
I j recently upgraded to the case and you will still be able to fit a card in the top pci slot. Just make sure to wrap up the clip on the heatsink in electric tape so you don't get a short. The clip will most likely touch a card mounted in that slot.
Featured Topics
mecurt78 ·
Posted in Troubleshooting0 -
4
jonrosalia ·
Posted in LTTStore.com Merch1 -
amir2927 ·
Posted in CPUs, Motherboards, and Memory1 -
4
rb19 ·
Posted in Graphics Cards5 -
3
yepnew ·
Posted in New Builds and Planning3 -
1
1
