What's a good signal expander that's not too expensive?  Do they even work that well.
  • CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard Ram: Team Zeus Blue 16GB (4 x 4GB) DDR3-1600 Memory GPU: Asus GeForce GTX 970 4GB STRIX Video Card Case: Phanteks Enthoo Pro ATX Full Tower Case Storage: Crucial MX100 128GB 2.5" Solid State Drive, Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive PSU: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply Display(s): Asus VG248QE 144Hz 24.0" Monitor Cooling: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler Keyboard:Corsair K70 RGB Cherry MX BrownMouse: Razer Deathadder Operating System: Microsoft Windows 8.1 (32/64-bit) PC Part Picker URL: http://pcpartpicker....aze101xx/saved/
https://linustechtips.com/topic/351356-signal-expander/
Do you need a signal expander?
Or could you just wire an ethernet cable from your router directly to you computer?
Case: NZXT S340 || CPU: i7 4790k || Cooler: Hyper 212 EVO || GPU: GTX 770 || Mobo: Z97 PC Mate || Storage: 240GB Sandisk Extreme Pro || RAM: 4x4GB 1333mHz
https://linustechtips.com/topic/351356-signal-expander/#findComment-4777203
