Front panel fans h440
Go to solution Solved by WoodenMarker,
Ive just ordered some NF-A14s PWM for my radiator on the top of the case. This case is starved all round to be honest. (I think the PWM fans run at 1500 and the FLX ones run at 1200?)
Just trying to decide whats best for the front.
I've got about £60 for the front 3 so i should be able to get 3 decent fans. The noctuas are only like £17 each. Just unsure :S lol
2 NF-A14's should perform similarly to 3 NF-F12's while being quieter.
Hey folks,
Just wondering on what peoples opinion was on the best fans for the front of a h440?
SP or AF fans?
The front of the case is pretty starved because of the panels.
Was thinking of 3 Noctua nf-f12 (static pressure)
Or do you think some good air flow fans would be better? If so which ones?
(Remember the front is starved by the panel and the hdd cages are behind the fans).
Many Thanks :)
Cpu: I7 5930k @4.2Ghz, Mobo: Asus x99-S, Ram: 16gb Corsair Vengeance ddr4, Gpu: x2  Evga super-clocked GTX 980's in sli,
Case:  Nzxt H440 Razer Edition, Storage: 250gb samsung 850 & x2 WD black 2TB.
PSU: 1050w Seasonic X-series gold. Cooling: Nzxt Kraken x61.
https://linustechtips.com/topic/351350-front-panel-fans-h440/
A combination of the two are important. I'd suggest getting 2 NF-A14's if price isn't that big of an issue.
https://linustechtips.com/topic/351350-front-panel-fans-h440/#findComment-4777135
https://linustechtips.com/topic/351350-front-panel-fans-h440/#findComment-4777196
https://linustechtips.com/topic/351350-front-panel-fans-h440/#findComment-4777215
Thanks for the input bro :D
https://linustechtips.com/topic/351350-front-panel-fans-h440/#findComment-4777276
