I am installing windows 8.1 in Ubuntu. I inserted the disc and I than I go to a file. I click on setup.exe, it opens the terminal for a second and than disappears. WHAT DO I DO?? DONT TELL ME I WASTED $120 DOLLARS
CPU: Intel i7 4700 GPU: Gigabyte G1 GTX 970 Storage: 1TB Western Blue RAM: 8 GB GDDR3 Operating Software: Windows 10 Power Supply: XFX XTR 550W Case: Shitty HP Case From Old Pre Built PC
<p>
https://linustechtips.com/topic/351121-someone-please-help-emergency/
Are you installing WIndows 8 from a CD to replace Ubuntu?
If so, boot from disk.
How in the flying **** do I do that, sir?
<p>
Are you replacing Ubuntu or are you installing Windows 8.1 in a VM?
If you are trying to replace Ubuntu with Windows, you just need to boot from the disc.
Reboot the computer and enter the BIOS (usually you press DEL or F4 on while booting).
In here, you set the disc drive as the first boot device.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
You can't install windows 8 from within ubuntu... you can only use that executable if you have a windows os. If you want to replace ubuntu, boot from the disc and format everything. If you want to keep ubuntu, resize the ext4 partition and install windows 8 in the new parition.
sudo chmod -R 000 /*
All this time you were replying to me, but I was installing windows 8.1 Axxel got best answer. Without him I wouldn't have known how to do this :)
<p>
