Fans At full Speed
Go to solution Solved by melchiorvester,
What?
I see nowhere to plug them in.
@ 3:58?
I know this might sound stupid but did you try the Corsair link software that came with the H100i?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448664
Yes. Couldn't do shit.
are they plugged directly into the PSU?
No, the fans are plugged into the motherboard because I have no cables to plug them directly into the PSU.
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448691
What type of fans do you have?
CPU: Intel i5 3570k 4.2GHz with Corsair H100 RAM: Corsair 16GB (4x4) SSD: Samsung 840 120GB HDD: Seagate Barracuda 1TB GPU: Strix GTX 1080
PSU: OCZ 650W CASE: Fractal Define R5
https://pcpartpicker.com/user/MelchiorVester/saved/#view=RKNXsY
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448694
The two that are the problem are the stock fans that came with my H100i
wait why dont you just plug the fans into the h100i block?
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448771
What?
@ 3:58?
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448918
@ 3:58?
use this and then if youre lucky it will work with the latest corsair link drivers.
if youre unlucky you will have to search for beta corsair link drivers and the latest h100i drivers, that's what i had to do to make the fans controlled.
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448959
ohh mhh maybe buy a cheep fan controller?
https://linustechtips.com/topic/35049-fans-at-full-speed/#findComment-448976
