So I'm trying to undo my i.d 1/2 o.d 3/4 monsoon fittings but the entire thing (barb and tube) is coming out instead of just the compression part how do I fix this or how can I unscrew it thing with this problem in mind?
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/34974-compression-fitting-problem/
You over-tightened it or under tightened it at the component.
Use cloth to get more grip and use pliers if you have to.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
