Do cable extensions lower the power going into what they're plugged in to?
Main Rig
CPU-
AMD FX 8350 | CPU Cooler- CM hyper 212 Evo | GPU- Radeon HD 7970 | RAM- G.SKill Ripjawz X 2x4 | Storage- 1TB WD Black | 128gb Plextor Ms5 | Case- BitFenix Shinobi   | Motherboard- Gigabyte AM3+ UD3 | PSU- Rosewill hive 750 watt
 Media PC
CPU- A10-5800k | GPU- Onboard | RAM- Ripjaws X 4Gb | Storage- Seagate 1TB | Case- Bitfenix Prodigy M | Motherboard- MSI A75M-E35 | PSU- Antec 350W Basiq
https://linustechtips.com/topic/34885-cable-extensions/
Man , don't buy cable extension even though your psu may not be fully modular... get some MDPC it's better and cheaper
It is modular, but dont want to do sleeving, what is MDPC?
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/34885-cable-extensions/#findComment-447068
This stuff.
Regarding the original question: The power going into a component really
shouldn't change. What could be slightly affected is the PSU's voltage
regulation due to the double wires (which are used for voltage sensing, which is
necessary for voltage regulation) stopping at the input for the extension (ideally
you would want to measure the voltage at the contact point with the M/B, not at the
contact with the input side of the extension). But this effect should be minimal
and negligible.
Bottom line: As mvitkun said, as long as the extensions are of good quality there
won't be a problem. There are so many people using extensions that we would have
heard about it by now if there was a large-scale problem with the concept.
EDIT:: Just as a side note: I wouldn't recommend running extensions for extreme
overclocking because for that those tiny differences in voltages actually may
become relevant. But I highly doubt that that is your usage scenario. ;)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/34885-cable-extensions/#findComment-447436
This stuff.
and negligible.
only using  8 pin and 24 pin extensions, they're both made by silverstone tek
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/34885-cable-extensions/#findComment-447578
Considering Silverstone's usual quality I think you have nothing to worry
about then. The voltage sense thing should be negligible unless you have
very high currents running through those double wires on the 24 pin.
https://linustechtips.com/topic/34885-cable-extensions/#findComment-447615
