So I designed my rig around portability
http://pcpartpicker.com/p/3kQGD3
But in the future was thinking of running two 970's in sli
I would like to do this but still keep my PC easy to move to my friends houses and between my parents
https://linustechtips.com/topic/348618-portable-matx-case/
Running two 970s won't work on that board because it is ITX and they only have one PCI-E slot, but other than that everything looks good but you'd also want to upgrade that case to mATX if you want dual 970s, I know BitFenix has a good mATX case but I forget the name right now.
My Build
 - i5 4670k @ 4.4GHz - MSI z87m Mobo - 16Gb 1866MHz RAM - MSI R9 290 - Samsung 840 EVO 250Gb - 2 x 1Tb WD Blue - CX600m - H55 AIO cooler - Fractal Node 804 - Lg 25um64-s Ultrawide screen monitor -  http://pcpartpicker.com/user/colec18/saved/9FKXsY
https://linustechtips.com/topic/348618-portable-matx-case/#findComment-4744793
I know that I'm just wondering if you guys know a case that supports matx but is still portable.
You are probably thinking about the prodigy m but I would like more options
https://linustechtips.com/topic/348618-portable-matx-case/#findComment-4744803
