I need help with overclocking. I've never done and CPU OC before.
The processor is an Intel Core i7 4770K in a ASUS Sabertooth Mark 2 Mobo water cooled by Corsair H80i (120mm radiator).
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/348571-i7-4770k-oc-help/
welcome to the Linus Tech Tips forums!
you might look to our members guide on overclocking @ProKoNhttp://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
you have all the right elements, now to move the performance needle a bit more.
https://linustechtips.com/topic/348571-i7-4770k-oc-help/#findComment-4744292
