Will they work together? No.
But you can, say, connect one monitor to the dedicated and another to the integrated. That way your second monitor doesn't steal GPU power when gaming.
Or, if your motherboard supports Virtu, you can allow switching between integrated and dedicated for power savings. Virtu is kind of terrible software, though.
If you're talking AMD, there are some dedicated cards that can work together with an APU in a "hybrid crossfire" mode, but they're so low-end that they're not worth buying.
IMO the best reason to have both is to have a backup if your dedicated GPU becomes problematic.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/34780-graphics-card-power/#findComment-445323
yes indeed. well, if the card happens to be a 7 year old card and compare it to the latest integrated graphics then that may not be the case. but most of the time, yes.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/34780-graphics-card-power/#findComment-445327
Depends on what you mean by "better". Gameplay wise, on the Intel HD Graphics side of things, it won't make a huge difference. However, if you're transcoding video, Intel Quick Sync will make a huge difference in conversion times. For AMD's APUs, this also depends on whether or not you have a compatible card to "crossfire" with the integrated graphics. You will get some boosts in video transcoding as well, but from the benchmarks I've seen, not as big of an improvement as IQS.
https://linustechtips.com/topic/34780-graphics-card-power/#findComment-445400
