Cable Management Tip
Solved by ELSknutson,
looking to finish my 1st build of a red/black theme, im using a maximus hero 7.
What cable i needed to buy for a neat looking on my window case, 24pin,6in,8pin whats else?
depending on the card you will need a 8 pin CPU 24 pin Motherboard and 8pin 6 pin for gpu ( depending on Gpu )
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
