So I installed the tech preview of windows 10 on one of my PCs and the realtek hd audio drivers are not working i keep getting the error code 0x000005b4
Please Help
dont use them?
could always use the Microsoft audio drivers :)
you should be able to use the 8.1 x64bit driver with Win 10
make sure you get the correct driver for your PC
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
