I was working on my computer and all of a sudden the gpu fan ramped up to 100% and my screen went black. I took off the side panel and it rebooted successfully, however the issue repeated itself 10 minutes afterwards. I then left it alone for an hour and it worked fine with the side panel on and off. Does anybody know why this is happening or how I can fix it?
My specs:
CPU: i5-4950
CPU cooler: Stock Intel cooler
Motherboard: Asrock z97 anniversary
PSU: Roswill 650w 80 Plus Gold
Gpu:  Asus Directcu II R9 290
Case: NZXT Source 530
https://linustechtips.com/topic/346854-gpu-fan-issues/
Is the cooler on the GPU dust-free?
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/346854-gpu-fan-issues/#findComment-4722423
Yes it is. I only built the system a few months ago.
Just because you built it a few months ago doesn't mean it's dust free. I take mine apart every month and have to dust it and at that point it's already VERY dusty.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/346854-gpu-fan-issues/#findComment-4722487
I just cleaned it using compressed air and the next time I started it it had the same issue.
Is it overclocked? If so did you change the voltage? Also when you reply make sure you quote the person :)
Current PC:
https://linustechtips.com/topic/346854-gpu-fan-issues/#findComment-4722580
Sorry about that I'm new around these parts :) . No, it's not overclocked at this time.
Hmm. Try the GPU on another motherboard if you can, or a different GPU if you can.
Current PC:
https://linustechtips.com/topic/346854-gpu-fan-issues/#findComment-4722640
