All parts looks solid. Just 1 question. Do you really need cpu water cooler? As i have read hyper 212 or 412s would have similar temperatures as nepton 120xl. Ofc if you are planning to oc it in hardcore mode till the very last drop mb few degrees will be a difference for you. But i would recommend to put hyper 212 or 412s. And invest rest of the money mb for a better case like nzxt h440 or enthoo and overall temperatures may be even better.
CPU: i7 4790k @ 4.4 GHz                                                 Case: Fractal Design Define R5                       SSD: Samsung Evo 850 250gb          Monitor:  Benq GL2760
   GPU: MSI GTX 970 SLI (+140 Core|+400 Mem)               Motherboard: Msi Z97-G5                                 HDD: WD blue 1TB                             CPU Cooler:  Hyper 412s
      RAM: 16GB HyperX DDR3 1600MHz                                PSU: Cooler Master v850                                 Storage: Adata HV610 1TB                  OS: Windows 10
https://linustechtips.com/topic/346819-first-pc-build/#findComment-4722073
Yeah Im not really planning on overclocking the CPU too hard so I will definitly consider that.
https://linustechtips.com/topic/346819-first-pc-build/#findComment-4722207
Do I really need 750w though? I picked seasonic because of great reputation.
A 750W will see you set for SLI. Also the EVGA is made by SuperFlower who are also very good. They make the EVGA G2/P2/T2 units as well.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=393
https://linustechtips.com/topic/346819-first-pc-build/#findComment-4722215
Very true.  Definitely nothing wrong with future proofing.  Thanks for feedback!
https://linustechtips.com/topic/346819-first-pc-build/#findComment-4722235
