Because my previous topic is down I ask. Best AIRFLOW fans layout for Corsair 300R + there will be h110i gt. As I say wanna use all fan places if its possible.
mount you rad as exhaust at the top rearmost spot. fill rest of the top as exhaust or intake your choice. the front should be intake the rear should be exhaust. sides i would just close off or use as exhaust  because of no filters. use all 140mm fans for best noise/airflow. glhf. you have a price limit we can recommend fans and whatnot.
https://linustechtips.com/topic/346369-airflow-fan-layout/#findComment-4716782
