Hey guys, I posted an older build on here a while back, and I've been tweaking my build ever since. I think I finally have everything figured out, but I wanted to check again just to make sure I'm not overlooking anything important. I plan to game in 1080p with this build and am looking to run the Witcher 3 on high/ultra specifically. Thanks!
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($178.49 @ OutletPC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($78.89 @ OutletPC)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  ($69.98 @ OutletPC)
Storage: Mushkin ECO2 240GB 2.5" Solid State Drive  ($88.98 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($329.99 @ Amazon)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($42.85 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.99 @ NCIX US)
Wireless Network Adapter: TP-Link TL-WN781ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($14.50 @ Mwave)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($138.99 @ NCIX US)
Total: $982.66
Generated by PCPartPicker 2015-04-07 17:39 EDT-0400
https://linustechtips.com/topic/343482-first-build-advice/
I really dont see any problems with it, although upgrading to a 4690 for a processor or using a samsung EVO series ssd might not be a bad touch, although you may juuuusst barely spill over 1,000$ if you do that. I'm not positive, but I think your 970 will be overpowered for such a cpu, but this rig will still destroy games at 1080p (the 970 is a beast)
https://linustechtips.com/topic/343482-first-build-advice/#findComment-4679177
Total: $982.66
If you are planning on runnning a 970, you might want a little more power from your PSU, I think 500w might be the minimum but better to go up 100w to be safe
https://linustechtips.com/topic/343482-first-build-advice/#findComment-4679179
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($82.98 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($96.99 @ NCIX US)
Case: Corsair 300R ATX Mid Tower Case  ($49.99 @ Newegg)
Total: $1052.39
Generated by PCPartPicker 2015-04-07 18:20 EDT-0400
I went a bit over the price limit, but this build has better quality parts and will preform better.
RIG: CPU: i5 6600k @4.8GHz 1.34v  CPU Cooler: H100i  Motherboard: Asus Z170-AR  RAM: Corsair Vengence LPX 2400 (2x8GB)
HDD: Seagate Baracuda 2TB  SSD: Samsung 850 Evo 500GB/PNY 240GB  GPU: Gigabyte G1 Gaming GTX 970  PSU: EVGA G2 650W
Please use PcPartPicker, and paste the "BB" code when posting your build!
https://linustechtips.com/topic/343482-first-build-advice/#findComment-4679473
Total: $1052.39
Oh cool, I really like this build! I can probably save up a little more to cover the extra cost too, thanks!
https://linustechtips.com/topic/343482-first-build-advice/#findComment-4680777
