This is everything I plan on using to build a decent gaming pc. If you have any suggestions or if you see a problem with this build please let me know so that I don't get the wrong parts.
CPU:AMD FX-6300 6-Core Processor Black Edition-$99.99
Motherboard:Gigabyte AM3+ AMD 970 SATA 6GBPS USB 3.0 ATX DDR3 1600 Motherboards GA-970A-DS3P $74.99
Graphics Card:EVGA GeForce GT 740 Superclocked Single Slot 4GB DDR3 Graphics Cards 04G-P4-2744-KR $99.99
Case:Sentey Gs-6008 Plus Stealth Mid Tower $42.99
Power Supply:EVGA 500W 80PLUS Certified ATX12V/EPS12V Power Supply 100-W1-0500-KR $42.03
RAM:Kingston HyperX Fury 8GB kit (2x4GB) 1600MHz DDR3 CL10 DIMM-Red $62.99
CPU Cooler:Cooler Master Hyper 212 Evo-CPU Cooler with 120mm PWM Fan $34.99
Storage:WD Green 1TB Desktop Hard Drive:3.5-inch, SATA 6Gb/s, IntelliPower, 64MB Cache $52.99
https://linustechtips.com/topic/342991-planning-my-first-build/
This is why I'm here. What would you suggest?
Someone might be able to give you more accurate answers as I'm not in the USA, but here's something that I would do:
- Change the CPU to Intel i3 4150 (~$110)
- Change the Mobo to some budget H97 chipset (~$75)
- Remove after market cooler, you don't need it for Intel, they ran so cool without overclocking.
- Change WD Green harddisk to WD Blue, faster access time if not mistaken.
- Change GPU to GTX 960 or Radeon 280/285
This should still be under $600.
---Edit---
Just learn how to use pcpartpicker because it's not relevant to me, but here goes:
PCPartPicker part list: http://pcpartpicker.com/p/367tbv
Price breakdown by merchant: http://pcpartpicker.com/p/367tbv/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($104.95 @ SuperBiiz)
Motherboard: MSI H97M-G43 Micro ATX LGA1150 Motherboard  ($74.99 @ NCIX US)
Memory: G.Skill Sniper Series 8GB (1 x 8GB) DDR3-1600 Memory  ($51.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Best Buy)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  ($199.99 @ Amazon)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($44.90 @ Amazon)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Amazon)
Total: $581.80
Generated by PCPartPicker 2015-04-06 22:52 EDT-0400
A lot of controversies maybe, especially the single channel DDR choice, but many post online shows dual channel memory doesn't do much for gaming.
https://linustechtips.com/topic/342991-planning-my-first-build/#findComment-4672491
