I was watching Gopher's "Beginners Guide To Modding Skyrim" and in the first part. he says that if Steam and Skyrim are on the C Drive then it would make the process more difficult because you would have to run NMM As administrator
Can anyone comment on whether that is still the case or not
The C Drive is my SSD which is why Skyrim would preferably go there
Thanks
 Case: Define R5 I GPU: G1 GTX 970 I CPU: i5 4690k I RAM: G.Skill Ripjaws X I PSU:  EVGA 750B2 I Cooler: Noctua NH D15
MB: ASUS Z97-A I SSD: Crucial MX100 256GB I HDD: WD Black 1TB
https://linustechtips.com/topic/342254-skyrim-modding-question/
As long as your the administrator on your computer your fine
https://linustechtips.com/topic/342254-skyrim-modding-question/#findComment-4662545
Skyrim load times aren't very long so it'd be fine on a hard drive. I think as long as you don't install it inside of ProgramData you'll be fine. Try Skyrim/NMM in a folder like Documents\Skyrim
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/342254-skyrim-modding-question/#findComment-4673871
Just keep Skyrim and NMM out of program files and you'll be good.
Intel i7 6700k @ 4.8ghz, NZXT Kraken X61, ASUS Z170 Maximus VIII Hero, (2x8GB) Kingston DDR4 2400, 2x Sapphire Nitro Fury OC+, Thermaltake 1050W
All in a Semi Truck!:
http://linustechtips.com/main/topic/519811-semi-truck-gaming-pc/#entry6905347
https://linustechtips.com/topic/342254-skyrim-modding-question/#findComment-4675892
