Just as the title says. I'm considering a new build which generally upgrades somethings that I couldn't afford to "splurge" on before. Although I found myself putting in parts that are almost equivalent to the ones I have now (like a 700W power supply, 12GB of RAM) Which parts are ok to reuse?
https://linustechtips.com/topic/341787-reusable-parts/
Technically speaking,. any part that still works properly and is compatible with your build can be reused.  Since we don't know what you're using right now, nor what you plan to upgrade, it's hard to know exactly what you'd "want" to reuse.
Case: HAF XBCPU: 4690kCPU Cooler: NH D15Motherboard: Gigabyte Gaming 7 | RAM: Hyper X FuryVideo Card: G1 Gaming 970SSD: 850 EVO |  PSU: Supernova 550 G2 |
https://linustechtips.com/topic/341787-reusable-parts/#findComment-4656738
yea sorry about that, I'm still deciding on what I want, but I figured If I could keep some prats I could build around it and not have to worry about them.
https://linustechtips.com/topic/341787-reusable-parts/#findComment-4656748
Well, what do you have planned and what do you have currently?
The Rig: NZXT H440 M3 (Green and Black) (Ncase M1 coming soon!!) | Intel Core i5-4690k x BeQuiet PureRock Slim | EVGA GTX 1060 6GB SSC  | ASUS H81i Plus | 12GB EVGA SSC @ 1600MHz | Seagate Barracuda 2TB | Sandisk Ultra II 480GB | Corsair SF 450| LG 29" Ultrawide | CoolerMaster Quickfire Rapid TKL | Corsair M65 Black Sennheiser HD 558 (MOD) | Audio-Technica ATR 2500
https://linustechtips.com/topic/341787-reusable-parts/#findComment-4656792
http://pcpartpicker.com/p/Ykpc7P
this is what I have I have planned.
I would say keep the PSU and the RAM.
Kinda off topic, but why in the world are you using a reference cooler for your GPU?
https://linustechtips.com/topic/341787-reusable-parts/#findComment-4656833
I don't plan on over-clocking my GPU so the potential temps don't worry me.
I don't overclock my GPU either, but non-reference cards are quieter, while offering higher clock speeds. That translates to better performance.
And they cost a hell of a lot less.
https://linustechtips.com/topic/341787-reusable-parts/#findComment-4656895
The card that I have listed wasn't the best choice obviously
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125683&cm_re=gtx_980-_-14-125-683-_-Product
this offers clock speeds just as good at a cheaper price.
https://linustechtips.com/topic/341787-reusable-parts/#findComment-4656931
