Hey all,
I'm relatively new to powershell, i figured out how i can export the home dirrectorys for a username I have it a text file.
get-aduser -identity (get-content c:\demo\users.txt) -properties homedirectory | out-file C:\demo\home.txt'
Only issue is -identity only lets you use one username not multiple
I will have to change to get-aduser -filter and filter by samaccountname i believe but unable to get it to work, any help would be awesome :D
https://linustechtips.com/topic/341749-powershell-get-aduser-issue/
You could try something like this...
## Output user directories$Source = Get-Content $args[0]$OutFile = Get-Content $args[1]Foreach ($User in $Source){	Get-AdUser -Identity $User -Properties HomeDirectory | Out-File $OutFile}
I'm too lazy to check it against an AD right now, but I believe it should work.
save it as a ps1 and call it "script C:\path\to\users.txt C:\path\to\outfile.txt"
Hey all,
Try:
cat users.txt | Get-Aduser -Properties HomeDirectory > C:\demo\home.txt
or (if the Get-AdUser does not properly read those users from the pipeline)
cat users.txt | %{Get-Aduser -identity $_ -Properties HomeDirectory} > C:\demo\home.tx
I do not have an AD right now to test it, but it won't be hard
According to technet:
https://technet.microsoft.com/en-us/library/ee617241.aspx?f=255&MSPPError=-2147217396
Accept Pipeline Input?
true (ByValue)
pipelineInput
The Identity parameter is accepted from the pipeline, so the first option:
Should work. You can even try something like:
cat users.txt | Get-Aduser -Properties HomeDirectory | select Identity,HomeDirectory | epcsv -Encoding UTF8 -Delimiter ';' -NoTypeInfo -Path C:\demo\users.csv
To have a nice csv ready to be opened with Excel, or:
cat users.txt | Get-Aduser -Properties HomeDirectory | select Identity,HomeDirectory | ogv
For a nice window
