A good variable speed Pump?
Solved by Shaqo_Wyn,
Hi everyone,
I´m planning to watercool my PC. So my favorite Pump would be the Swiftech MCP655, but here in Germany I´m not able to get it without expensive shipping:(.
So I´m searching for another reliable pump with a speed controller:D.
Looking forward to your suggestions.
(Hope my English isn´t too fucked up
The MCP655 is one of many D5 rebrands, all are good.
Check if you can get your hand on a EK D5, Alphacool VPP655, XSPC D5.
VPP655: http://www.aquatuning.de/wasserkuehlung/pumpen/d5-serie/d5-pumpen/10620/alphacool-vpp655-single-edition <-- there you go ![]()
For 10 EUR more you can get the PWM version from the same website.
