Computer Won't Start (First Use)
Go to solution Solved by Andystan19,
[sOLVED]
The motherboard is faulty: the graphics chip doesn't work
Hi all,
I have just bought some computer components and when i assemble the computer and start it up, no picture is displayed to my monitor.
I know that the system is working as the CPU fan is spinning along with the power supply fan and my panel fan.
I have no OS loaded and I should be able to enter the BIOS screen (or am I wrong?)
Here is a list of my components and thanks for the help :)
MSI B85M-P33 V2 (Motherboard)
Crucial Ballistix 2 x 4GB (RAM)
Intel i3 4130 (Processor)
WD Green 1TB (Storage)
Benq DL2215 LED (Monitor)
Coolink MPT-5012P (PSU)
Many thanks again,
Andy Stanton
https://linustechtips.com/topic/341343-computer-wont-start-first-use/
Couple things.
- Make sure the monitor is on
- Make sure the monitor has the correct input set as its source
- Make sure the 4 pin CPU power is plugged in.
Yes, on the first boot and any boot after that you are supposed to be able to enter the bios screen.
Those components should work together just fine. Did you check all of your connections. If no display is popping up and you correctly installed everything then there's something wrong. You should be able to boot into your bios without any OS installed so that's not the issue.
Case: Corsair 760T White PSU: Corsair AX1200i Motherboard: Asus Maximus VII Formula CPU: I7-4790k Cooler: Stock Cooler Ram: Corsair Vengeance 16GB 2400mhz GPU: Asus Strix GTX 970
Smart suggestion KDub! Make sure that the 4 pin Power Cable used to power your processor is connected to your motherboard. Its usually in the top left area of the motherboard.
Hi all,
Many thanks again,
Andy Stanton
Check this thread and make sure you have done everything here:
http://linustechtips.com/main/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
Thanks for the feedback everyone,
After reassembling my PC 3 times with no change to the problem, I am beginning to think that the power supply is faulty.
Do you think that this is a plausible explanation?
Many thanks,
Andy Stanton
