vga mobo ram problem
So, I have a old motherboard, asus p5vd2-vm with an intel pentium 4 3.0 Ghz with 3 gigs of ddr2 ram at 333 mhz
I was looking today through the bios and I found a option to change the ram speed. There were 3 options: 333mhz, 480mhz and 660mhz. I have two sticks(both kingmax and they can run at 800mhz (this says on the sticks))
So... i choosed the third option(660) and saved everything. I didn't made any other changes but when the pc restarted to apply the changes the screen detected no signal. I turned on the speakers to see if it boots but it didn't.
I don't have any other screen
my video card is an hd5670
So, what can i do?
Would it help if i would reset the cmos by disconnecting the bios battery(if I will find it)?
Sorry for my writing, i'm using the phone
Please help me. I'm really desperate
Does your RAM stick say DDR2-800? Because this means it can only run at 400mhz. With DDR RAM, you double the speed in mhz to get the DDR speed. This means DDR3-1600 is actually running at 800mhz, DDR3-2400 at 1200mhz, and so on. 660mhz would have the RAM at DDR2-1320, which is not what you would have thought.
Clear the CMOS and keep the RAM settings the way they are at default.
