Linking power conversions, need help
Go to solution Solved by SonoDanshi,
You could also just buy a sata to 8-pin adapter and use that....
http://www.amazon.com/gp/product/B007Y8FSMQ/
I recently purchased a EVGA GTX 960 ssc that requires a 8 pin PCIe connector. I later realized that my power supply has an 8 pin CPU power connector but not an 8 pin PCIe connector. I have two free SATA connectors and I was wondering if there are any negative effects of doing this: converting the 2 SATA to a single 6 pin PCIe and taking that 6 pin, combining it with a 6 pin coming straight from the PSU and converting the 6 pins to a single 8 pin connector for my GPU. This is my first time doing this so I don't want to mess it up.
Thanks,
shnightsite
https://linustechtips.com/topic/340429-linking-power-conversions-need-help/
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
