Cooler Master Hyper T4 Preformance
Solved by CharlieR1,
Any cpu that is at 60 degree at idle doesn't seem right at all.
You should definitely remount it and reapply the thermal compound.
I would definitely try remounting the CPU using an "x" pattern when applying the thermal paste.
Thanks guys! Will try that.
toxic_worper ·
Posted in New Builds and Planning5 -
2
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
5
3
Doctah ·
Posted in Peripherals3
