Hello there!
I am planning on constructing a wall mounted gaming pc and all the planning is going just fine except for the cooling bit. As it's hanging on the wall freely out in the air I don't know how much of it I need and not even if the situation boosts the  cooling or makes it worse. I'm planning on water cooling the cpu with a Corsair Hydro H110, but am uncertain about the GPU. Will the amount of fans (two in my case as I'm using a GTX 770) be enough or do I have to water cool that aswell? If that is the case I would instead need a fully custom (and much more expensive) water loop, which really isn't preferable.
If you have any thought on the topic then please respond :)
https://linustechtips.com/topic/339558-gpu-cooling-on-wall-mounted-pc/
  • 2 months later...
I am currently building a wall mounted pc awell, I am going to be using a arctic cooling accelero hybrid ii for my GPU and a Corsair  H110 for my CPU, and my Acrylic Clear lid will have a 200mm Cooler Master Mega flow going straight onto the MB when Gaming.
