Where do i buy one ? I looks super cool,and since i already have a neckbeard would look better.
When everything else Fails,Crowbar IT. - Half-life
Being a Linux user is sort of like living in a house inhabited by a large family of carpenters and architects. Every morning when you wake up, the house is a little different. Maybe there is a new turret, or some walls have moved. Or perhaps someone has temporarily removed the floor under your bed." - Unix for Dummies, 2nd Edition (Found in the .sig of Rob Riggs)
https://linustechtips.com/topic/339366-valve-lanyard/
Have you checked the Valve merchandise store?
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/339366-valve-lanyard/#findComment-4627096
They don't have one.
https://linustechtips.com/topic/339366-valve-lanyard/#findComment-4627387
