So I have purchased an Intel Wireless-AC/Bluetooth laptop wireless card, but everytime I have installed it and go to turn it on, the laptop will sit at the BIOS POST test and will not move. It will move unitl I have to shut it off manually and then swap the cards back for the original and then it will boot up.
I would like to use the Intel card as it has a much better performance than the card I'm currently using in the laptop right now. I've even tried following some of the videos on YouTube on how to install wireless cards properly, but work to no avail.
The Laptop I'm using is a Gateway NV55S.
Here is a link to the card I want to use: http://www.newegg.com/Product/Product.aspx?Item=N82E16833106242&ignorebbr=1
https://linustechtips.com/topic/338947-gateway-wireless-card-problem/
