Hey guys,
I have a 4690k overclocked to 4.6ghz @ 1.275v. O/c was done automaticly via AI Suite and is perfectly stable. I started logging the temps and during gaming it goes to mid 60s ©. During Aida64 stress test the temp slowly claims to 69c and doesnt go above that.  (+20mins).
The problem comes with Prime95. During Blend test it maxes out in the lower 60s ©. But if i select the SMALL FFTs test the temps  slowly climb to 90c!
Is this normal? Would you guys suggest backing up on the overclock?
System:
H100i
4690k
Asus z97-a
NZXT S340
295x2
i7-5820k @ 4.6ghz w/ H100i || Asus Sabertooth x99 || Gigabyte 980ti G1 ||  EVGA 980ti SC || 32gb DDR4 2666mhz Gskil || 1tb WD Black HDD || Samsung XP941 256gb M.2 PCIe || EVGA 1300w G2 || Corsair 540 w/ Silverstone Sound Dampening Foam || Logisys RGB Led  || Corsair M65 Mouse  & Corsair RGB k70 || A lot of Corsair SP120s
https://linustechtips.com/topic/338346-overclock-temps/
Hey guys,
System:
H100i
4690k
Asus z97-a
NZXT S340
295x2
first of all don't use Prime95 in Devil's canyon CPUs . second use bios for overclocking third at 4.6 ghz 1.27v are good use bios and i bet it will stabilize below 1.25v . that will give you much better temps . stress test it for 8 hours then see where will temps stop rising . with H100i at 1.27v volts after 20mints without hyperthreading 69C is high .do go above 1.3v and 75C.
Gaming Rig: Asus Maximus VII Ranger - Core i7 4790K - Corsair H100i - Corsair vengeance 16 GBs ( @2133) - Asus GTX 980 - Intel SSD 730 (480 GBs) - Seagate Barracuda 3 TB - CM Cosmos SE - Corsair AX 760i
Bugout Laptop: Dell E6430 - i5 3340M - 8GB Ram (@1600) - HDD 1TB WD - SSD 240GB intel (boot drive).
https://linustechtips.com/topic/338346-overclock-temps/#findComment-4614038
Thanks, Ill mess around with the voltage and see where it can be stable at.
So should i stick with Aida64?
https://linustechtips.com/topic/338346-overclock-temps/#findComment-4614201
yup Aida64 is best till now for me i own the same Asus board and 4790K . so we are on same boat . :D
https://linustechtips.com/topic/338346-overclock-temps/#findComment-4614226
Thanks a lot for the help! A quick change to 1.248v already shows about a 10c drop. Ill keep messing with it and report back
https://linustechtips.com/topic/338346-overclock-temps/#findComment-4614266
glad to help mate . you're welcome . yes it will drop when i had 4690k mine was stable on 1.190v at 4.5ghz .
https://linustechtips.com/topic/338346-overclock-temps/#findComment-4614287
