Starting Point for Custom Loop
Solved by shert73,
I was going to go that route, but I ended up just going custom loop. Im pretty sure that the pump is halfway decent. Vut a cpu and 2 gpus and at least another 240 rad seems to be a lot, not sure about it honestly. The fittings are G1/4 so upgrading the fittings is no big deal. Its still going to be costly either way. My advice would to just skip the AIO and save for a full custom loop. Less hassle but in the end it will look and work better. If your going to invest that much might as well get the best, I wouldnt cheap out on watercooling gear.Hey,
I would like to begin easing myself into building my own custom loop for my CPU and GPU's. However, my budget and lack of experience would make jumping in headfirst a bad idea right now. So I have been looking at the Switech h220x AIO as a viable option for beginning the transition and simply upgrading it as I go. My questions are:
How many radiators/components can the on board pump and rez be reasonably expected to cool?
Is upgrading this platform as strait forward as it seems it would be?
Should I consider an alternative?
Thanks
