Higher clock speed = higher IPC ?
Solved by cesrai,
IPC isn't just a term for "single-core performance" as a lot of people seem to think these days. It means instructions per clock. Increasing frequency makes more clocks occur per second and hence, more instructions executed per second. Same amount of instructions during each clock though. There's just more of them. IPC is inherent to the architecture and there is no setting you can change which will increase or decrease it.
No, IPC is seperate from clockspeed. IPC stands for Instructions Per Cycle. A Cycle is another word for Hertz. IPC is the amount of intructions a processor can do in a single cycle.
