So, in the next couple months I will be building my first Rig, @1500€ bidget including monitor KB and mouse and this is what I have so far
CPU: INTEL Core i5-4690K
MB:GIGABYTE GA-Z97P-D3
RAM:  Crucial Ballistix Sport  2x8 gb 1600Mhz
GPU: MSI GTX 980
PSU: CX430 80 PLUS Bronze
Case: Corsair carbide 200R
Display: ASUS VE247H
So, what I need help is in the motherboard, is it good? Should i replace it?
I was also thinking in changing the CPU to a i7 4790K to make it more "future proof" and go down to a 970, I can easily upgrade a GPU later but if the socket changes I can't swap CPU, would love to know your input.
Is the case good for 1st time builds? Enough airflow or need to get more fans?
Know ZERO of displays, don't want anything very fancy and I though this one was good.
RAM was the cheapest I saw on my store as 16gb 1600mhz go.
And please shoot away keyboard+mouses, I will probably just buy the ones that fit in the budget and please my eyes
Thanks to everybody with patience to read all of this and sorry for any errors
EDIT: forgot about the storage, 250gb 850EVO+2TB WD green
https://linustechtips.com/topic/337906-first-rig-suggestions-please/
Good except you need a bigger PSU. get something like this, http://pcpartpicker.com/part/evga-power-supply-220g20850xr
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
600+ PSU
Z97 is a very nice mobo
Bullshjt. Ignore those guys. A single 980 could be handled by a 430w PSU. The thing is, 430 only has 1 PCIe connector, so you'd need a molex to 8-pin adapter.
Even so, get a 650W psu, just for the sake of being able to do SLI. If you are sure you won't ever do it, just stick with a 500w one.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Um kinda rude? I'm suggesting 600+ just to be safe...
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
Thanks for the input so fa, I didn't know it only has one connection, I will get 500 or 600 just to dont have to buy the molex to pcie adapter, what about the dilema on top, should i stick with the i5 and the 980 or swap for i7 with 970 for easier upgrade later?
