So i've been playing Arma 3 and have been struggling with fps. i was hoping someone could help me with overclocking my pc, in order to make the most of it.
System Specs:
Gigabyte 78LMT-USB3-Motherboard
AMD Radeon R9 280X 3gb GDDR5-Graphic Card
AMD FX 8350 4.0Ghz Eight Core-CPU Model
8GB DDR3 1600mhz Performance Ram-Memory
1tb Seagate Barracuda Sata 6Gb/s 64mb Cache 7200rpm-Hard Drive
Corsair CX600 80 Plus Bronze Certified 600w Power Supply-PSU Size
My PC has 'overclocking potential'
Thanks a lot!
https://linustechtips.com/topic/337750-overclocking-help/
Don't bother...
Arma3  + AMD FX 8350  + Radeon R9 280X  = Stay away from that game.  :ph34r:
https://linustechtips.com/topic/337750-overclocking-help/#findComment-4606297
First off this is the second new thread you made about this within 5 minutes of each other >.>
Second you should watch some videos explaining how to overclock properly, you were already given a reply with a video linked in it in your other thread
Third that motherboard won't be great for overclocking and I see no aftermarket cooler listed, and the stock heat-sink is nowhere near good enough for overclocking, so I would not recommend it if that is the case.
Fourth you probably won't see much of an improvement in your game performance unless you do a pretty large overclock, which would need at least an AIO water cooler and even then I would only think maybe 10 fps increase or so.
Sorry if this came off as a bit rude, I got annoyed that you posted the same thing twice (wasn't even a double post they have different content) >.>
CPUAMD FX 8320 @4.4 GHz 1.212 vcore Motherboard - Asus M5A99X R2.0 RAM - G.Skill Ripjaws X 16 GB 1866 GPU - Asus Gtx 970 Case - Corsair Vengeance C70 Military Green Storage - 120 GB Samsung 840 Series, 1TB WD Black,  240 GB Corsair Force LX PSU - EVGA 750W G2 Cooling - Noctua NH-D14 Keyboard Corsair K70  Mouse - Logitech G502
https://linustechtips.com/topic/337750-overclocking-help/#findComment-4606350
