Ive got two types of PCI-e cables, one 8 pin that splits into two 6+2 pins, and an 8 pin to a 6+2 pin, i will be using these cables to power 980's, however i don't know which ones i have to use, or if it even matters, Ive attached images of the cables themselves, the 8pin to two 6+2pins is the one thats not tied up, whilst the 8pin to 6+2pin is tied up. Can i just use one of the split cables to power the 980, or would i have to use two of the non split cables?
post-217102-0-54440400-1427632178_thumb.
post-217102-0-10160400-1427632184_thumb.
https://linustechtips.com/topic/337538-cable-problems/
Don't really think it matters that much which ones you use because its from the same manufacturer, if im mistaken then yes there's a discussing point there. But I do recommend the non split one in order to distribute it right without having to go through extra cable management depending on your chasis.
https://linustechtips.com/topic/337538-cable-problems/#findComment-4603819
