Just setting up my first pc and my motherboard (msi97s) doesn't come with wifi I know the fastest and cheapest way of Internet is wired but my computer is upstairs and my router is down stairs so I was wondering what the best way to get internet from there would be? I want to game on this and I don't want lag. Should I get one of those cheap usb wifi dongles if so could you guys recommend any?
https://linustechtips.com/topic/335989-my-first-pc-needs-internet-help/
If you're gonna go with wifi i'd get an actual card that uses PCI. Get a 500mbs card or higher depending on the speed of internet you have running through your wifi at home and you'll be set. You wont get quite the connection you would if you went wired but that;s just a sacrifice you'll have to make. And to be honest, i run one of my pc's on wifi just to limit some of the cables running around and i dont need it really, and its really not that huge of a difference in most cases.
I picked this up: http://www.bestbuy.com/site/netgear-n900-dual-band-wireless-n-usb-adapter-black/4962089.p?id=1218586474932&skuId=4962089and I still get a 15 ping. 50mb/s down and 10 up on wireless with that, and I'm on a different level from my router, and far away.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
Buy a powerline network adapter
Specs:
PC:CASE: FD Define r6 | CPU:Intel Core i7-8700k | MB: MSI z370 PC Pro RAM: 32GB Corsair vengance LPX 3000 GPU: Asus rx 6900xt Tuf STORAGE: nand 500GB Samsung 970Evo plus ; Game Storage: 2TB Samsung 860QVO Storage: 2 x WD Green 4TB | PSU: Corsair RM850x | CPUCooler: Noctua NH-D15   DISPLAY: LG 27GL850
