Saving User Input Python HELP!
Go to solution Solved by Nineshadow,
Either store it in your RAM (bad idea), or use actual files that are stored on your drive.
How to read :
import string file = open("test.txt", 'r') lineFromFile = f.readline( ) file.close( )
How to write :
import string file = open("test.txt", 'w') file.write("Write this to file\n") file.close( )
How can I save user input in python, I'm relatively new and just dicking around atm. I'm making a login page where users are required to enter a username and password, once they enter the username and password I want the data to be stored so that they can re-use that same login info. Is there an BIF's that I don't know about that can help? Thanks
https://linustechtips.com/topic/335477-saving-user-input-python-help/
How to read :
How to write :
How to read :
How to write :
Thank you very much
