So, this is my first time building a gaming pc, I do have a "gaming pc" right now, but it was a prebuilt computer i bought years ago, and switched out the PSU and added a GPU.  If you guys could check out the build I have set ready to order now, and give me some tips and suggestions, it'd be awesome!  One more thing, I am building the PC completely through Best Buy so I can finance the computer, so I can pay for it over a couple of months, instead of one lump sum, Thanks again!
CPU - Intel core i7 4790k
RAAM - 16 GB (8x2) Corsair Vengeance DDR3
GPU - EVGA GEForce GTX 970 4GB
MOBO - The bestbuy site just calls it "Asus - Desktop Motherboard - Intel Z97 Express Chipset - Socket H3 LGA - 1150"
PSU - Corsair CX 750M Modular
HDD - 1 TB Western Digital
Case - This is where I have 2 options, either a CoolerMaster HAF912, or a Corsair Carbide 200R, could use some help here.
For all of this, it was around $1300 give or take a 20 or so, plus I added some small stuff including wifi adapters and what not.  I know I don't have an aftermarket cooler so I can't overclock out of the box, but i plan on upgrading a few things in this as time goes on, including an SSD and a good liquid cooler.  Any help will be much appreciated friends! :)
https://linustechtips.com/topic/335333-first-time-build-help/
I don't recommend going with best buy, try using pcpartpicker.com
I do recommend the 200r, good looking from what I see :D
 badges badges badges badges badges badges badges badges badges badges badges badges badges
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574088
and your PSU is a bit too op, tone it down to 500 or 600
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574092
Is it just for gaming? If so you don't need the i7 or the 16 GB but if you are streaming/rendering a lot the i7 and 16 GB helps.
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574101
I dug this up from the depths of my pcpartpicker stuff:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: Gigabyte G1.Sniper M5 Micro ATX LGA1150 Motherboard  ($133.98 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($329.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($91.69 @ NCIX US)
Case Fan: BitFenix Spectre Pro LED 86.7 CFM 140mm  Fan  ($15.99 @ SuperBiiz)
Total: $1233.00
Generated by PCPartPicker 2015-03-25 21:08 EDT-0400
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574113
looks like bestbuy is charging you around $150 extra - I suggest buying through newegg and such
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Total: $1158.41
Generated by PCPartPicker 2015-03-25 21:11 EDT-0400
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574141
I know pc part picker works better, but it's just more convenient for me right now to finance the parts and pay it off in 2-3 months then to just flat out put up the money, so I don't mind paying a slight premium for the ability to finance.  Also, I know the i7 and 16 GBs of RAM is overkill for gaming right now, but I'd like to "future proof" the pc as much as I can now.  Same goes for the overkill on the power supply
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574169
I5-4690K and 8GB is fine for gaming. Better to put resources into an ssd and after market cpu cooler than more powerful cpu and additional memory.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($239.99 @ Best Buy)
Motherboard: Gigabyte GA-Z97X-UD3H-BK ATX LGA1150 Motherboard  ($150.99 @ Best Buy)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($86.99 @ Best Buy)
Storage: Sandisk Ultra II 240GB 2.5" Solid State Drive  ($110.99 @ Best Buy)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($55.99 @ Best Buy)
Case: NZXT Source 530 ATX Full Tower Case  ($89.99 @ Best Buy)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($95.99 @ Best Buy)
Other: EVGA - GeForce GTX 970 4GB GDDR5 PCI Express 3.0 Graphics Card - Black ($379.99)
Other: Cooler Master - Hyper 212 EVO 120mm CPU Cooling Fan - Black ($34.99)
Total: $1245.91
Generated by PCPartPicker 2015-03-25 21:53 EDT-0400
https://linustechtips.com/topic/335333-first-time-build-help/#findComment-4574489
