Changing boot drive without reinstall?
Go to solution Solved by Pesmerga,
uhm you can try with the samsung magician, it comes in the box, clone the drive. :o
Hey guys.
one of my SSDs is on it's way out and I've bought a 128gb Samsung 850 pro to replace my 2 60gb Vertex 3's in Raid 0 but... how can I transfer all the data/windows install onto my new drive and run windows from it without the need of a reinstall?
Corsair 650D, i5-4690K (Corsair h50 cooler), Asus ROG maximus VII Ranger, Asus GTX 980ti Strix, 16GB Corsair Vengeance pro series Red (2x8gb 2400mhz), Corsair HX850W, Asus Xonar Essence STX, Sennheiser HD595 / Beyerdynamic dt 770 pro 250 ohm, Samsung 850 pro 128GB / WD black/blue/green, OCZ vertex 3 60gb . Corsair M40/Corsair k70.
https://linustechtips.com/topic/333741-changing-boot-drive-without-reinstall/
uhm you can thy with the samsung magician, it comes in the box, clone the drive. :o
thanks, trying this now.
Samsung Data migration... so easy! plugged in the Samsung SSD, installed the disk, two clicks, 15minutes later it copied it and I've just removed the old SSDs, brilliant!
