ATX case
Go to solution Solved by RazerZ,
AFAIK Cooler Master's HAF XB fits your description, maybe there are a few other test bench style cases as well.
Then there's always the option of buying a custom case, but it will get expensive.
Hi forum!
Im looking after a ATX chassi with the the mother board being flat like in the thermaltake X9series, i wonder if some one have a other case than that. that can house a ATX motherbaord and prefilled liquidcooling loop.
Thanks for the help in advance!
https://linustechtips.com/topic/333576-atx-case/
