don't need thermal paste hyper 212 evo comes with it, don't need sound card as it is literally 0% better than your motherboard's at 10$.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/332909-first-build/#findComment-4517928
so other than that, is just right?
let me whip up a better build stay tuned to this post
here ya go :)
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.99 @ SuperBiiz)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard  ($56.98 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($65.98 @ Newegg)
Storage: Crucial BX100 120GB 2.5" Solid State Drive  ($66.99 @ Micro Center)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card  ($183.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Total: $680.99
Generated by PCPartPicker 2015-03-22 12:54 EDT-0400
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/332909-first-build/#findComment-4517968
is the evga 430w that cost about 40 bucks good?
go with my build up above
https://linustechtips.com/topic/332909-first-build/#findComment-4518024
$750 before rebate:
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($56.99 @ Amazon)
Storage: Seagate Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ Amazon)
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card  ($172.98 @ Newegg)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($32.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($24.99 @ NCIX US)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  ($35.98 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($92.00 @ B&H)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $716.79
Generated by PCPartPicker 2015-03-22 13:02 EDT-0400
https://linustechtips.com/topic/332909-first-build/#findComment-4518042
here ya go :)
Total: $680.99
This is all well and good, but the cost of the optical drive and OS aren't included.  The true cost of this rig is $830, significantly above the original $660.
https://linustechtips.com/topic/332909-first-build/#findComment-4518051
ok, let me whip up another one with optical drive and OS  BRB
done
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($104.95 @ SuperBiiz)
Video Card: MSI Radeon R9 270 2GB TWIN FROZR Video Card  ($164.99 @ Micro Center)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.78 @ Directron)
Total: $704.74
Generated by PCPartPicker 2015-03-22 13:05 EDT-0400
https://linustechtips.com/topic/332909-first-build/#findComment-4518070
mostly gaming
Definitely go with either the i3 4130 or the i5 4440 then.
You don't need an SSD right away as it does not improve your FPS performance.
Grab a single stick of 8 GB RAM so you have the room to add a second 8GB if you ever need it.
@Jasonlim What is your budget for this PC?  $700?
@Jasonlim Do you need a blue ray, and do you need wireless?
https://linustechtips.com/topic/332909-first-build/#findComment-4518219
and for the bray, i like watching movie on my computer, so yeah
$801 before rebates:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.99 @ SuperBiiz)  <<Stock cooling is fine
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)  <<Has a USB 3.0 Header for the front panel on the case
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($56.99 @ Amazon)  <<<motherboard only has two RAM slots, so you can add more with a single 8GB stick
Video Card: Sapphire Radeon R9 280X 3GB Tri-X Video Card  ($219.99 @ Newegg)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($32.99 @ SuperBiiz)  <one of the best cases at this price range, easy to build in
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.99 @ SuperBiiz) << I spent a little more on this to get a more capable adapter
Total: $763.80
Generated by PCPartPicker 2015-03-22 13:25 EDT-0400
You will love gaming on something like this.
https://linustechtips.com/topic/332909-first-build/#findComment-4518296
