I have an old computer that I use only through Teamviewer, in this computer there are two graphics card, one integrated and the second that I have mounted. The problem is that if there isn't any monitor plug in the second graphics card when I use teamviewer without a monitor plug in the computer uses the integrated graphics card.
With this options can I disable the integrated GPU?
Thanks
post-153474-0-34029200-1426957160_thumb.
post-153474-0-87429400-1426957181_thumb.
Sorry if my english isn't perfect
Gaming PC
CPU: Intel Core i7 4770K @3.50GHz Cooling: Corsair H80i Graphics Card: ASUS GeForce GTX 780 Motherboard: ROG MAXIMUS VI HERO RAM: Corsair 16GB @1600MHz PSU: Corsair AX760 SSD:Samsung 840 EVO 250GB HDD:Western Digital Black 1TB Headset: Logitech G930 Wheel Logitech G27
iMac Mid 2011
CPU: Intel Core i5 @2.70GHz Graphics Card: AMD Radeon HD 6770M 512MB RAM: 8GB @1067MHz SSD: Samsung 845 EVO HDD:Western Digital Red 2TB
https://linustechtips.com/topic/332261-remote-computer-integrated-gpu-problem/
-snip-
Plug into the dedicated GPU, not the motherboard for the monitor. Otherwise it will just output using integrated. Plugging into the dedicated one will use that.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
but the problem is that i haven't a monitor for that computer, can I "simulate" a monitor modify a dvi connector?
Gaming PC
iMac Mid 2011
