Here is the list of stuff  http://pcpartpicker.com/p/7ntgHx
What do you think of it for an entry level gaming build? I'll be upgrading to a gtx 970 and an i7 4790K later on (of course, I will need a new motherboard with that)
Any thoughts on that chassis? I do move from place to place a bit, so I thought a cube case would be easier to move. Anyways, any thoughts, ideas, or suggestions will help, thanks.
https://linustechtips.com/topic/332168-thoughts-on-build/
Would try to get the 1150 socket into the build, rather dumb to buy AMD if you know that you are going to switch, maybe the g3258 and an AMD GPU because those are fine aswell
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/332168-thoughts-on-build/#findComment-4508817
Good point, I didn't even think of that :l   I'll probably get the g3258 with an 1150 motherboard like you siad, then upgrade it later.
https://linustechtips.com/topic/332168-thoughts-on-build/#findComment-4508986
