650D Fans
Solved by WoodenMarker,
i will be shopping at http://www.ipmart.com.my/and http://www.lelong.com.my/
If you can tie down the fan since it's not actually a 200mm, go with a FS 200RB: http://www.lelong.com.my/nzxt-fs-200rb-200mm-silent-fan-11-blade-rifle-bearing-lingloong-K942839-2007-01-Sale-I.htm
Otherwise, Megaflows aren't as good but will fit without cables ties or the sort. http://www.lelong.com.my/cooler-master-megaflow-20cm-red-led-silent-fan-r4-lus-07ar-gp-easyit2u-158866485-2015-12-Sale-P.htm
NF-A14's for top intake: http://www.lelong.com.my/noctua-casing-fan-14cm-900-1050rpm-nf-a14flx-castleit-K1398182-2007-01-Sale-I.ht
NF-s12b for rear exhaust: http://www.lelong.com.my/noctua-casing-fan-12cm-1200rpm-nf-s12b-redux-1200-pwm-castleit-K1857319-2007-01-Sale-I.htm
