everyone is saying that fans on gpus are better than the blowers
but i'm wondering, why do all original card from Nvidia and AMD have blowers?
because thier the cheapest form that you can buy
and blowers are not Terrible *nivida* just not as practical,  amd ones do suck a lot,
https://linustechtips.com/topic/331689-blower/#findComment-4503157
amd blowers dont suck... its just that on the 290x no blower can keep up with that much heat, not even an nvidia one if you could put one on a 290x
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/331689-blower/#findComment-4503289
First and foremost it's because of case compatibility. If someone has a scrappy case with a single case fan, a blower won't cook itself to death.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/331689-blower/#findComment-4503323
