So when i was in call with Kingston tech support, the lady pointed out to me that windows can only boot to a drive that is the c drive, well right now my ssd is the drive, and i need to make it into the c drive.
so i know i can unassign a drive by clearing it, and i am fine with doing that for my ssd. but then i cannot format it in windows with out making it into the d drive, so how do i make it into the c drive outside of windows.
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/331174-making-d-drive-into-c-drive/
Try re-wording this to help clear things up.
such as SSD = D:/
and your HDD = C:/
and you want to change it so your;
HDD = X:/
and SSD = C:/
What is your current state, and what do you want to have?
such as SSD = D:/
and your HDD = C:/
HDD = X:/
and SSD = C:/
my hdd is the c drive and my ssd is the d drive
i need to make the ssd into my c drive
My Rig
Total: $2074.22
Hey Thebman712,
Disconnecting your HDD and connecting only your SSD would enable you to assign the letter C on the SSD. Having the HDD as C-drive indicates that you are booting from it. The letter C is reserved for the OS partition.
If you do a fresh install of the OS on the SSD, make sure the HDD is unplugged to avoid any conflicts. Changing the letter of the HDD might result in some problems and you might have to reinstall all your applications that are there. The rest of the data should be OK.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
